Looking for beta-testers
Re: Looking for beta-testers
Sure will. You don't have to ask me twice
This update took away my ability to use the HTC styled pops up in compact mode.
How can I get them back ?
(This is what greets me when I go to the .apk link to try to re download also)The requested URL /smartkeyboard/beta/SmartKeyboardPro_4.1.0-beta.apk was not found on this server.
I removed this feature as most people (except you
) complained about it...
But it's back with the new option "extended compact/T9" in the language settings (download the beta again)!
Will do. What's wrong with these people
Done. Thanks, I'll have to buy you a cold one, one day.
Everything works like charm - black predicting bar is great...
Thanks Cyril !!!
Sent from SGS ...
Thanks Cyril !!!
Sent from SGS ...
I concur with fvs114, looks good.
Actually I just discovered the smart dictionary was completely broken... I fixed it and at the same time made it faster again to load. Can you download and try again?
After the first two installs the Gingerbread Skin seems to be struggling with a noticeable lag. But with the third download whatever fix that was provided to the Smart Dictionary also fixed the problem with the Gingerbread skin. (At least on my device).
Test phase is (already
) over, 4.2.0 is now live on the market! Thank you
