Looking for beta-testers
boowalley
Phone: EVO 4G Android 2.1
Re: Looking for beta-testers
Post by boowalley »
:lol:
nicky041192
Phone: HTC Wildfire Official 2.2
Post by nicky041192 »
Any news on what will be new in the next version?
*cough* Copy, Cut, Paste *cough* :P
Or an online repo for skins ;)
The next version will have enhancements for European languages, with the new option "Accents priority", and fixes for tablets (especially Xoom)
It can be downloaded here.
About the online skins repository, it's only related to the web site, not the app itself, but anyway I hope I will find some time to do this one day.
New feature added in the above beta: "touch to correct" (enabled by default), which allows to bring up the prediction bar when the cursor is moved to an already typed word.
Please give your feedbacks to this version!
serenewaffles
Post by serenewaffles »
It works to bring up the suggestion bar, and selecting new words also works in English. T9 next button does not work properly. It looks like it cycles once properly, but seems to break after that.
EDIT: One other thing: consider using that final decimal in the version number to differentiate better.
EDIT 2: When using the hardware keyboard on the Droid 2, clicking brings up the suggestion bar and I can't make it go away until I leave the text field.
EDIT 3: T9 next still works right for new words after re-editing breaks it.
EDIT 4: Using backspace to eliminate the space following a word so that you can re-edit it causes the next space to remove the word and enter a period as if you had pressed space twice. This occurs in T9 and regular qwerty (portrait).
EDIT 5: I haven't been able to reproduce the problem in EDIT4
EDIT 6: Sorry for all the edits. If you type a word and then tap it to edit it, it is then selected as if it is highlighted. Typing anything in this situation will cause the word to be replaced completely. This makes the entire message uneditable if you have the keyboard set to not insert a space after word suggestions/insertions.
ock
Phone: Galaxy S i9000, Froyo
Post by ock »
I can reproduce this issue too, touch to correct suggestions work great though. :D
ock wrote:
serenewaffles wrote: EDIT 6: Sorry for all the edits. If you type a word and then tap it to edit it, it is then selected as if it is highlighted. Typing anything in this situation will cause the word to be replaced completely. This makes the entire message uneditable if you have the keyboard set to not insert a space after word suggestions/insertions.
Selecting words after a touch actually only works starting from Gingerbread, so for now I removed this feature from the beta (maybe I'll put it back again later if I find a solution to this problem)
boowalley
Post by boowalley »
:? Whew, I couldn't reproduce the option you guys where talking about. I have Froyo. Cyril's last post cleared up my confusion :)
Just to clarify again, I was just talking about "If you type a word and then tap it to edit it, it is then selected as if it is highlighted". The whole feature "touch to correct" works on all versions of Android.
boowalley
Post by boowalley »
Okay. I got cha.
