Localization for all languages
Re: Localization for all languages
I see this, if long press the button
So obviously you don't use "English (international)" layout, but Czech or Hungarian QWERTZ layout, which don't have these accents...
OK, so you use "English (International)" as language, but then I'm 100% sure you changed the option "Force latin layout" and set something else than Default there.
Yes, that was the problem(Force latin layout)cyril wrote:OK, so you use "English (International)" as language, but then I'm 100% sure you changed the option "Force latin layout" and set something else than Default there.
Thank you for helping me.
I´m working on translation for Slovenian language, it is almost finished.
I´ve finished translation for Slovenian language on crowdin website. Both files are finished 100 % and also every entry is checked/updated at least 2
Ok, I'm waiting for a release with my translation
and of course Slovenian dictionary for Smart Keyboard
http://www.dexilog.com/smartkeyboard/fo ... f=2&t=1345
I´ve also made backups of xml files, if something goes wrong.
You can try it herefvs114 wrote: Ok, I'm waiting for a release with my translation![]()
Thank You !!!cyril wrote:You can try it herefvs114 wrote: Ok, I'm waiting for a release with my translation![]()
I'm very satisfied with Slovenian translation, probably professional translator would't make it better..
I will test it further and if I'll find anything I'll let you know.
Hi Cyril,
I've made some corrections, and re-tested everything and I think translation is now good enough for ordinary release.
