Here is the beta of the 3.9.0
New features:
* Calibration tool
* Skin preview
* New swipe actions: cursor movements and space
* Farsi layout
* Bug fixes
As usual let me know if you see problems
(the beta will be removed when this version is released officially)
Looking for beta-testers
fekish
- Phone: 0035799347957
Re: Looking for beta-testers
Calibration seems to be working ok...
Skin preview is smooth and quick!
I can see a swipe sensitivity now, however for the message under i can read only:
Set the sensitivity of gestures. Warning:
if you increase the sensitivity too much,
Until there, the other message cannot be shown...
fekish
Cyril, i think you should add for height key: back to default.
If we chose the skin again from start, the height it will go to default again?
Is there anything else new on the new beta?
Zarch
- Phone: HTC Desire 2.2
Agree with this. I played around with the height just to test, but had no idea what the default height should have been when I tried putting it back.fekish wrote:Cyril, i think you should add for height key: back to default.
Also, does messing with the height have a negative impact on any calibration you've done?
Well, the default height is in the middle position of the slide. I will see how to add a reset button anyway
And yes, you should restart calibration after changing the height, as you will probably type a different way
New in the latest beta:
you can now set the key height in both portrait and landscape, and you can click on the phone icon to reset the value to the default
- PROXIMO
- Phone: Wildfire
is this beta any different than v3.10.2
I mean there is beta for testing, but doesn't say what changes it contains (or this is for security measures)
It was the same until one minute ago, but now you can test a new feature here: the "large space bar" option!
Enhanced
- Phone: Captivate
Just enabled the Large Space Bar option and it works very well. Only suggestion I would have is to automatically input a space after the comma (when long pressing on the space bar). Just a small annoyance as I'm sure 100% of the time, everyone typing grammatically would put a space after a comma anyways. Would just eliminate the extra step of tapping the space bar one more time after putting in a comma. Just a small thing though!
Thanks for listening to our suggestions. Only requested the larger space bar a day ago and it's already incorporated. Love the community interaction and you listening to our feedback. This is definitely the best keyboard on the market.
mcdaaniel
- Phone: Droid Eris
I'm very happy to see that such a great keyboard is still getting development to become even better. If you need any testers I'd be more than happy to help out.
