When typing the suggestion engine sometimes loses it, even on words that it knows. Was typing "circonstance" in french and the suggestions stopped at when I reached "circonsta".
In some occasions, when typing a word that draws a blank in the suggestion engine, the right suggestion appears after erasing and retyping the word, even with the same typo if there was one.
Works fine though but these mishaps make me slow down a lot. Anyone with the same problem ?
auto suggest sometimes doesn't work
Re: auto suggest sometimes doesn't work
I have noticed that, as well. I haven't yet figured out any sort of pattern to it.
Found a bug causing this symptom. It's hopefully fixed in 1.22.2 ! The pattern was: start pressing on a key, move your finger and release the finger on another key; it was messing up the prediction algorithm
Glad to see you found and fixed the bug. I've noticed an improvement.
For 2012 spring,Franklin and Marshall offers many new style franklin marshall jackets for men and women.Most men like doing sports, comfortabel clothes is very important for them. franklin marshall t-shirts are designed for sports men.It’s more comfortable with high technology materail.
