Gingerbread 2.3 and Space Bar
- Phone: Android 2.1
Hi Cyril, I'm currently running Gingerbread 2.3 (2.3.1, if you need specifics) and for whatever reason, i'm noticing the space bar isn't as responsive as when I was using SKP on my Samsung Vibrant. Is this a known issue? There will be times when I know I've hit the space bar, but it won't register so you'll see words stick together likethis sometimes as I'm thumbing out a message. Is anyone else experiencing this?
chtamina
Re: Gingerbread 2.3 and Space Bar
unfortunately the space bar isn't enough responsive even on 2.2 I think.
Sent from my HTC Desire
To be honest, after some more use, SKP in general seems to not be as responsive and quick on Gingerbread 2.3 as it did on my Samsung Vibrant running 2.1.
Is SKP optimized for Gingerbread 2.3, Cyril?
I seem to have better luck typing with Android's stock keyboard on 2.3 (it doesn't ever miss space bar presses), however, it doesn't have as robust a feature list as SKP. Would love to continue using and supporting SKP. Hopefully it'll be optimized for Gingerbread soon?
Cyril? Hope you'll get in touch.
