Hi, i bought the latest versions of SmartKeyboard PRO. I would use T9, but it seems doens't works. For example if i would write "Ciao", the keyboard write "Agam", seems to be the same that I have t9 enabled or disabled, it write always "Agam". And this for all other words.
Thanks for any reply.
T9 doesn't works! (Italian dictionary)
Re: T9 doesn't works! (Italian dictionary)
i have fixed installing Italian for Smart Keyboard from Market.
