According to the User Guide, the long date format auto text (%D) should look like:
Tue, Sep 21, 2010
But when I define the auto text macro, my long date actually looks like:
September 21, 2010
Please fix or include a different style long date with the first format as it is more useful.
Fix long date format
Re: Fix long date format
Would like to bump this up. Any chance of fixing the long date format to the way it's supposed to be? I use that format all the time!
Indeed the code (or the user's guide
) is wrong, the long date format uses the android method DateFormat.getLongDateFormat(), which gives a different result. Looking at this
Just did the update to 3.13.0 - looks great! Thank you!!
