I red about problems with this tool and I have same problem - on english keyboard it works fine but on czech doesn't work at all - "Server error". Although czech language is not supported (google say), with original android keyboard it works great but with smart keyboard not.
//Edit: I found thread with link to new version, but it not works.
Speech to text - Czech
The_ERROR
- Phone: LG P500 Optimus One, Android 2.2 Froyo
Re: Speech to text - Czech
Indeed the reason is simple: I used "CZ" instead of "CS" for the language code (it's a mistake) so Google server doesn't recognize it...
Working on a fix
Working on a fix
The_ERROR
Yes, becouse we are using CZECH language it must be clear, that short name for our language must be CS!!
Anyway, this beta works great, so thanks for help!! Your keyboard is realy smart!
Keep going!!
lukewesley
This problem may be due to change of language.You can try to test beta with english.Hope so your speech to text will be solved.
The_ERROR
Quite old responce, check the date
It is working fine for while...
