Show Alt Symbol
- Phone: Android 2.1
Show Alt Symbol
Show Alt Symbol won't work unless Show Alt Labels is enabled too. Was this intentional? Since they are two different checks, and since I can check Alt Symbol without needing to check Show Alt Labels, I thought they were separate features...
Re: Show Alt Symbol
You are right there is a dependency between these options, I will change the setting for next version
Re: Show Alt Symbol
Thanks Cyril!
