Names?
goodie
Phone: Samsung Galaxy S
Names?
Post by goodie »
There's an option to use names in the contact list for suggestion,
but I don't get any suggestions for any names...
Could it be because they're in korean?
@ from time to time I also wish that the phone numbers could be inserted or suggested without me having to lookup-memorize-type them, but i guess I went too far. ;)
Re: Names?
Indeed it may not work in Korean I will look at this
About your second request, you don't go too far ;) You just need to enable "suggest numbers" option, and then they can be added to the user dictionary like normal words (or can use custom autotext for that)
