I dont know if this is actually a bug but lets say for example...this is a bad example but:
if i type nihaoma..then the first suggestions it gives is the 3 word phrase which is correct. However if all i want is the 'nihao' part of 'nihaoma' to be converted and the 'ma' part to be a different 'ma' then when i select the 2 word phrase 'nihao' from the suggestions, it gets rid of the ma part completely and i have to retype it.
also, if you could add pinyin with traditional characters that would be great
Chinese Pinyin bug
Re: Chinese Pinyin bug
Well this is not really a bug, if you pick a word manually, it will replace all your input... Let's say it's a missing feature
(did you see other keyboards working like this?)
Pinyin and traditional will be added later, hopefully
cow_like_object
yeah, google pinyin does it..haha ok yes missing a feature. thanks for the quick reply. its a very important feature needed to type fast though.
lyfbnc
- Phone: Samsung galaxy tab froyo
Just registered to say this is the reason I have to return this app and get a refund. Everything else was so perfect with smart keyboard. Unfortunately this is the one feature I cannot live without. Hope it will be coming soon.
cow_like_object
any updates on this?
