Your latest update is phenomenal, thanks.
Issue:
The letters on my keyboard are always capitalized when using the iPhone skin. This does not happen when using the Android skin
Letters on keyboard always capitalized on iPhone skin
- Phone: Droid 2.01
Re: Letters on keyboard always capitalized on iPhone skin
hi
That's on purpose, the iphone keyboard is like this!
But ok I see many people complained, so I will change this now
You are right! I just checked my co-worker's iPhone. I had the 2G iPhone long ago, I had forgotten the letters are always capitalized. I thought it was a bug, in which case, change it back!
But if you got lots of complaints, then you can leave it as is, I won't complain
The keyboard seems more accurate with the iPhone skin or I could just be having a placebo effect. Again keep up the great work!
Maybe add it back as an option. I kind of liked it. Less for the screen to render so might even help with speed in some cases.
Yeah, please could you add this like an option?
Just wait a few minutes, it will be in the next release
