great app and its so close to perfect.
the following words are examples of problems
we... well: we should be default selected for 93 keys
try ...trying: same problem as above
too...tonight: same problem as above
these short words are all recognized just suggested second or third for their exact key presses.
we, try, and too are all in user dictionary also but regardless even if not the long words shouldn't be suggested before short ones.
in general its trying to be too smart and in return losing functionality of basic t9 and what makes t9 so much more elite than other texting methods.
thanks and can't wait for a fix
travis
t9 not functioning properly
Re: t9 not functioning properly
Have you tried the smart dictionary option? It's precisely there to improve T9 suggestions by learning what you really use most
will try thanks
what I have learned in the past day of doing this is that it is not a solution for pure t9 functionality. words being suggested ahead of dictionary words really loses the idea of what makes t9 so much more elite than other methods of typing.
I'm never going to type the word "ac" more than "can" so "can" will always come up first for the 22 key press. that is just one example of course, I founf this to be a problem with many words.
the simple fix would be to make dictionary words more important than other future predicting words. normal t9 does not do this but it seems new Lapps trying to replicate it try and be too "smart"... think about making a true t9 that would totally rock
You are right, words with the right number of letters could get more priority, I will check how to do this for T9 / compact only
you are legit the man
your texting t9 app is so far superior in terms of speed even the second best one the HTC ime by Jonas is not even close to yours. I feel like with what I request deserves a donation
when you get to the on screen displaying the first choice real time you better expect one
Just bumping this idea since I already created another topic about it without searching first
Great work on this keyboard, I only wish I could help more.
Any estimate of when well be seeing this implemented?
Not yet, but it's still in the TODO list, hope I have time soon to work on it
Ok I added a new option "T9 length priority" in this beta version
Can you test?
Can you test?
