The suggestion bar doesn't show up in certain apps like the market.
Also, I love the android skin, but could you also make an iPhone skin? This application is exellent, you should be veey proud that you were able to execute it so well
suggestions don't appear
Re: suggestions don't appear
this is on purpose, the android framework tells the keyboard when to enable suggestions. But I will add an option to change this, as I was already asked
And yes I will do an iPhone skin
