Capitalize first letter of sentence on voice input.
coltswalker
Phone: Casio GzOne Commando / Android 2.3.3
Post by coltswalker »
NOTE: DEFER THIS FOR NOW.
The auto capitalization seems to work with several apps, but not with the text editor Ted. I may remove this bug report altogether when I am done testing it extensively with several different apps.
Original Message:
When using voice input, the first letter of the sentence is not capitalized. User must navigate back and manually correct case. Please advise if setting exists otherwise consider bug. Thank you.
Pro Version
tested in text editor called Ted.
update: It did capitalize the first letter of the sentence in my latest text message. Maybe this bug is present when using a text editor app but not when using the text message phone app.
