Typing in portrait mode and using the T9 mode, whenever I press the "ghi" button, the suggestion is ALWAYS the letter "g" and NOT the WORD "i".
This happens whether I use the Norwegian or English keyboard, and in both languages "i" is a common word.
I have tried re-installing without this changing. Can you please look into it and give me a reply?
pressing "ghi" button does not result in the word "I"
SamFerdinand
- Phone: HTC Desire S w/ Sense 3.0; Android 2.3.5
Re: pressing "ghi" button does not result in the word "I"
"ghi" should give "I" in English *if* you have T9 mode enabled.
Otherwise you can always define a custom AutoText to replace "g" by "i", for Norwegian
SamFerdinand
Thank you for replying, but that is de facto what it doesn't. It have been an issue for many months now. I did also add "i" to the User Dictionary though that did not improve anything.
cyril wrote:Hello
ChokDK
- Phone: Samsung Galaxy S2
This is also my problem - I have to edit "g" to "i" constantly.
Where to define that autotext - can't find where to edit?
The promised "redefine keys" is not to find? (danish language)
ChokDK
uhmm.. look what 5 minutes of search on the forum can do!
http://www.dexilog.com/smartkeyboard/fo ... 561#p43561
Try this one out - it works for me anyway (thanks again Cyril)
SamFerdinand
Thank you, it did work. I wasn't aware that the thread you linked to discussed my problem. I always check for threads discussing the same problem I encounter before starting a new one, but this didn't catch my attention it seems.
In any case, follow this link and see my new problem (!)
http://www.dexilog.com/smartkeyboard/fo ... 029#p44029
ChokDK wrote:uhmm.. look what 5 minutes of search on the forum can do! ;) :oops:
