Hello,
i have a problem with smart keyboard on Android 2.1 HTC DESERIE default Firmware!
Everytime when i change the settings it dosent change the keyboard. I try restart but i dosent helps.
Keyboard dont apply
Re: Keyboard dont apply
It works on the HTC Desire as on every phone, just follow carefully the instructions...
You need to long press in a text input box to have the popup menu appear, then choose "Input Method" then "Smart Keyboard Pro"
oaz1
- Phone: HTC DESIRE
Thank you! I dont know why i didnt find it...! You should tell it the user right in the app.
