This seems to happen constantly, so usually when I hit space it puts in a 'b'
This hasn't happened on any other keyboards I've tried.
I'm using an HTC Desire
Taps register higher than I tap.
Re: Taps register higher than I tap.
maybe the vertical correction (which is necessary on a touch screen) is too big for you. What is needed is a calibration tool, but that's already in the TODO list
Ok thanks for the quick reply, I'll just have to type slower for now
Asics Shoes For Men draw close going to be confirmed as upright footwear. Asics Gel Kayano 17 Shoes may be the flagship motion deal with Running shoes from ASICS, which not simply gives best aid collectively with a secure fit, but has long been generated with snugness in mind.
