Hi !
I am experiencing issues switching from T9 portrait mode to multi-tap.
When writting in T9, once you've accepted a word suggestion, it is not possible to add letters to the word using the multi tap fonction anymore, it only displays the first letter of the key, even if you press it twice or three times. That may be a problem because sometimes the suggestion is close to the word you wanna type but it's not the exact one so you may want to add a few letters ("s" for exemple) but it is not possible.
For example : when T9 is active, if you wanna type the word "polices", just accept the "police" suggestion, hit backspace to stick to the word and try adding a "s" after have T9 switched off. It won't work.
I hope you understand me as english is not my native tongue.
Multi-tap disabled after suggestion acceptation
Ultrabald
- Phone: Acer Liquid
Re: Multi-tap disabled after suggestion acceptation
indeed it's because suggestions are disabled when you correct a word. I will try to find a workaround to this problem..
Ultrabald
Still not fixed in version 2.5.3... that's dissappointing.
Asics Onitsuka Tiger Shoes are made with high technology and superior material. Every Asics Revolve Le Shoes are made carefully by designers. This is why Asics Onitsuka Tiger Shoes so popular in the world. I’m a fan of Asics Onitsuka Tiger shoes, I like Onitsuka Tiger Rotation 77 very much, only because they are so comfortable.
