Hey guys - new to the forum as I have recently been running into an issue.
Whenever I type "In" or "IM" regardless of how long I wait between pushing "I" and "N" the keyboard minimizes. Seems to be keys in that area, same thing happens with "um" and "un".
I originally thought it was due to the gestures aspect, but I changed it to where I could no longer swipe down to minimize and the effect still happened. I tried resetting the app - is there a way to reset all, or should I just uninstall and delete the directory in Astro Gallery?
Or are others running into this and found a solution.
I am using an HTC Evo running 2.3.3
Help! Smart Keyboard minimizes/closes
Re: Help! Smart Keyboard minimizes/closes
Indeed it seems to be a gesture issue, so it should not happen if you disable the "Down" gesture...
To reset all the settings the only way is to uninstall / reinstall the app
Thank you for the response.
I have turned off all gestures and the keyboard still minimizes, regardless.
I have also uninstalled and reinstalled the application, but the minimizing still continues.
Perhaps there is a spot in the internal memory I can wipe any errors or settings the uninstall does not? I cannot go back to using the Sense keyboard and need to find a fix for this!
Thanks again for the help.
