Just bought the pro version and now I cannot turn off the vibrate when I press a key nor can I get my sounds to work when I type.
Trial version had no issues.
Can't turn off vibrate or change key sounds
Reelgator
- Phone: 727-232-1561
Re: Can't turn off vibrate or change key sounds
Trial and Pro versions are exactly the same so I cannot give any explanation...
