Hi..i got one issue here..
Smart Keyboard Pro wont became the default keyboard after restart phone.(even "tick" the Smart Keyboard Pro checkbox- before restart)
Option for input method also unavailable..only the default Android keyboard appear.
The check box also for Smart Keyboard Pro is untick after restart...
Anyway how to solve this.
Phone Model : HTC HD2
Rom : Hyperdroid CM7 v2.1.0
Smart Key version : 4.4.1
android version : 2.3.4
Smart Keyboard wont! load...
ex5dream
- Phone: HTC HD2 , Android V2.3.4
Re: Smart Keyboard wont! load...
I would say there is a bug with your ROM, if it forgets the available input methods. Maybe you installed the app on your SD card (you must NOT do this for input methods) ?
