When using the t9 keyboard with the Danish I have not managed to get the Smart Dictionary to learn the word 'i' (which means 'in' in Danish) and it keeps suggesting a 'g' instead. I have also tried to add it to the user dictionary without any luck. Maybe the Smart Dictionary doesn't support one letter words...
I would appreciate any advice, thanks.
Cheers
Henrik
Smart Dictionary to learn one letter words?
hlfrandsen
- Phone: Samsung Galaxy sII
Re: Smart Dictionary to learn one letter words?
Indeed dictionaries don't support 1-letter words for several reasons (at least at the moment)
For your particular problem, define a custom autottext to replace g by i as explained in the user's guide.
hlfrandsen
Thanks for the fast reply and work around.
Cheers!
Cheers!
