Double tap works on the regular Korean keyboard (The one with less keys), but doesn't on the 단모음 Keyboard. Mostly need for double consonants.
Rooted Thunderbolt running Das Bamf 2.0.5
Multitap on 단모음Korean
sml7285
- Phone: HTC ThunderBolt (GB)
Re: Multitap on 단모음Korean
That's on purpose, a long press is required to get double letters with this layout. Why don't you use the short vowels layout if you want to use multitap?
sml7285
Thanks for clearing that up. I just wanted double tap for consonants because that's how physical keyboards are typically set up for Korean.
sml7285
sml7285 wrote:Thanks for clearing that up. I just wanted double tap for consonants because that's how physical keyboards are typically set up for Korean.
Any way you could add this as a feature seeing as option already exists in the preferences?
