Can not restore saved setings - Keyboard hang
polzovotel
Phone: Samsun Galaxy S i9000
Post by polzovotel »
On Samsung SGS i9000 with Darky rom - If I backup the keyboard settings and then try to restore them I get total keyboard app. hang.
Is there any workaround for this ?
I am using the latest version from Market (PRO version).
Re: Can not restore saved setings - Keyboard hang
Can you get the phone logs while this happens? Do you use app2sd?
polzovotel
cyril wrote:Can you get the phone logs while this happens? Do you use app2sd?
I do not use app2sd.
As for phone logs - did you mean enable "Enable debug Logs" option in Smart Keyboard advanced setting ?
No, I mean install "Log Collector" (or any similar tool) and collect the logs just after you get this problem (no need to enable debug logs)
polzovotel
cyril wrote:No, I mean install "Log Collector" (or any similar tool) and collect the logs just after you get this problem (no need to enable debug logs)
Ready - sent you PM
polzovotel
did you get the logs ?
Thanks.
kamzik
Phone: Samsung Galaxy S 2.3.3
Post by kamzik »
Same problem here.
I just bought Smart Keyboard PRO and wanted to import settings from TRIAL version.
Created backup.zip is corrupted and application hangs when trying to import backup. Also backup.zip from newly installed PRO version is corrupted and cannot be open also in computer. See attachment.
backup-pro.zip
corrupted backup.zip
(482 Bytes) Downloaded 303 times
polzovotel
for some reason it seems that Cyril ignoring this issue ...
The reason is that it's not a critical problem and I'm very busy. I will look at this one
polzovotel
I fully agree that it is not critical.
But droping a message here saying that would be appriciated.
