Lots of Text - Input Window Glitch
Re: Lots of Text - Input Window Glitch
By the way, to make investigation easier, do you have an idea of what words you typed before it happens ? It may be just a particular word (and I never had this problem as I never write in english on my phone)
I was just typing gibberish into a notepad app. The last 'word' I was typing before the crash was apparently 'ext'
So !! thanks to your log report I have been able to reproduce the problem ! There is a resource leak in the native dictionary code (I still have to find why), so if you type more than about 300 words, the dictionary will crash
Working on it !
Working on it !
Ok I found out the problem. It is FIXED in 1.2.4 (hopefully) !!!
Awesome, I'll give it a shot! Thanks! I assume the resource leak may also explain why SmartKeyboard Pro seems to get slower over time?
Does it get slower ? The main factor which can impact performance is the JVM garbage collection, which can freeze the phone for several hundreds of milliseconds. The leak I just fixed may also impact memory (I don't know to which extent), which would imply more garbage collection.
But anyway I am quite relieved now, I can work on more interesting things
Yeah, although I can't prove it, the performance does seem to decrease over time. I'll let you know if I still observe this behavior in newer builds. Thanks again for fixing this bug!
hogan men shoes haver luxury appearance because of the high quality leather. When you are wearing hogan women shoes, you can know how elegant, then you will fall in love with those good shoes.
