you're right, but here's another video where "ne" don't get priority on "me". I don't think it's autotext related this time (sent you via email)
the "smart dictionary" feature rarely works
chtamina
chtamina
Re: the "smart dictionary" feature rarely works
have you looked at the video I sent?
chtamina
I love this app but smart dictionary doesn't work, not in t9 mode at least.
Sorry, but once again the smart dictionary works as expected. I can see from your backup that in Italian you typed "me" 138 times, and "ne" 70 times, so the behavior is normal.
chtamina
cool, I'm glad you explained why it "looked like" it wasn't working, btw i'll make some test.
thanks again for your patience
chtamina
ok, here's another video where there's something that doesn't work properly.
when i tap ad "c'è" doesn't get priority over "ad"
i have nothing strange in autotext, but you can check yourself.
video and backup.zip sent in email
quatermass
- Phone: HTC Desire HD, v2.2.1
I find if I go back to a previous sentence then the auto correct completely turns off. I'd have to put in some spaces to get it to come back on. This is very annoying.
What is the link with the smart dictionary? I guess you are just talking about this feature requestquatermass wrote:I find if I go back to a previous sentence then the auto correct completely turns off. I'd have to put in some spaces to get it to come back on. This is very annoying.
efindley
I came on these forums looking for an answer to this exact question. I type "it's" twice as much as I type "its" (according to the database), but it always makes "its" the first priority. Kind of annoying, but I wasn't sure I was understanding exactly how this feature was supposed to work. I use the full qwerty keyboard. I did just turn the smart dictionary off and then back on again to see if that will make a difference. Time will tell.
