Hello. Can you add Czech layout?
1 normal + Ě Š Č Ř Ž Ý Á Í É
2 normal Q W E R T Y U I O P
3 normal A S D F G H J K L ů
4 normal Z X C V B N M ú
1 long 1 2 3 4 5 6 7 8 9 0
2 long Q W É Ř Ť Ý Ú Í Ó P
3 long Á Š Ď F G H J K Ľ ů
4 long Ž X Č V B Ň M .
This layout for qwerty like.
2 normal Q W E R T Z U I O P
4 normal Y X C V B N M ú
2 long Q W É Ř Ť Ž Ú Í Ó P
4 long Ý X Č V B Ň M .
This layout for qwertz like.
And, can you support hardware keyboard on Motorola Milestone ? For change language from keyboard like http://4pda.ru/forum/index.php?showtopi ... l=keyboard
(rukeyboard).
Thanks.
Czech layout
ajiekc905
- Phone: Motorola Milestone 2.01
ajiekc905
Re: Czech layout
I like the layout of qwerty. Some people may like qwertz.
I'll can suggest implement both layout.
Can you provide link to TODO list?
ajiekc905
Re: Czech layout
Hello.
Any news?
Any news?
Re: Czech layout
Not yet. Maybe I'll do it next week (by the way the todo list is not yet public)
ajiekc905
Re: Czech layout
Thanks.
How about the ability to support changes in hardware keyboard layouts in accordance with the selected language and the possibility of switching the language for example, using alt + space.
Do you need a list of words and, if so, in what format should the list.
Re: Czech layout
Translation of hard keys is not planned yet.
As for the dictionary, yes it would help to have a word list. The needed format is just a text file with the words ordered by decreasing frequency
ajiekc905
Re: Czech layout
Hello.
Any news about czech layout ?
Re: Czech layout
I added the QWERTY in 1.19.0, let me know if I made mistakes.
I had to remove the ú key as there is not enough room for it (it's accessible with the "u" key; by the way I could do a multitap for "u" if you want, in addition to the long press; I just don't know if "uu" exists in czech language
