Modify T9 order suggests
Simone
Post by Simone »
Hi! I've noticed a kind of bug in T9 function. It's about the order of the words suggested when I start to write, in particular way for short words.
Fort example, when I push 3 buttons, the T9 suggests me words longer than 3 characters, and often I've to slice the list to find the desire word, and sometimes I don't find the word (and I've to switch off T9 and use standard mode).
I'd like that, if I push n buttons, first results will have n characters and then the more probably words. I believe it's a simple change, and the behavior of T9 will be more similar to the original T9 function.
Simone
Re: Modify T9 order suggests
have you tried the option "T9 length priority" which does exactly that?
