Your keyboard is a MUST HAVE !
Just missing an advanced prediction dictionnary, as in Swift Keyboard, to be perfect.
Could you add this feature please? (in French also ! ))
Thank you, great job.
Frederic.
ok for move.
Advanced prediction = when you write a word, the software suggest you an usual following word.
Eg : if you write often "the door is open", when you'll write "the", you'll have a suggestion for "door", and then for "is", ...
Or if you write "of", you'll have sugestions "the" and "these", ...
Very quick with a good dictionnary !
Regards.
Frederic.
Hello,
this is actually the only feature that I am really missing. I was told that Swift Keyboard has this feature, but I have bought Smart Keyboard Pro and wouldn't want to switch to any other solution. Is there any chance that this feature will be added in near future? Even the standard Galaxy S2 keyboard has this feature and Smart Keyboard is so much better in man aspects, so it would be really nice if you could consider adding this feature. Please let us know if you will add this and if yes (what I hope your answer will be), when. I would need it in German.
Thanks a lot in advance,
Best regards,
Gabs
I have the Swift keyboard and that is the main reason I like it. However, I am a big theme fan and started looking at other keyboards because their themes are so limited. Smart keyboard seemed liked the best choice until I found out there is no prediction. I just switched to touch screen and after having a Blackberry texting is really difficult for me. I'd be willing to pay for the pro if it had the prediction feature. As of right now I am on the fence about Smart keyboard. Lovely themes but missing just that one feature slows down my texting and other reasons I use the keyboard.
Edit: I take that back about not buying the pro. Just got it the other day. Better to support a good developer IMO than wait to see if what I want will happen. This keyboard has made it easier for me text after using a Berry for so long.
