Managing the Apostrophe
Re: Managing the Apostrophe
Great Cyril! Thank you for your work
New option "Apostrophe separator" added in Text prediction settings in the latest beta. Can you try?
cool! it is working! i'll test it for few hours and let you know if there's something wrong with this latest beta
EDIT: yes it's working properly.
thanks
thanks
hello Cyril! i'll try your beta, too, thank you!
Yes, but now is hard to write > d' <cyril wrote:OK I will add an option to consider apostrophe as a word separator. Thanks for your patience
I must press > d < (number 3), select >d< from prediction bar (because the first predicted word is > e <, and > e < should be ever the first word )
delete the automatic generated space, and finally put the apostrophe,
Because if I press > d < and then > ' <, SKP write > e' < and the autotext e' -> d' doesn't work!
And....If I press 3 times > ' <
so... > ' ' ' <
without the "apostrophe separator", I use the autotext ' ' ' -> ! ! ! or the autotext ' ' ' ' -> ♥♦♣♠ (a ploy to have special characters pasted in dictionary from ad text editor )
But now with the new function, the apostrophe "breaks" the prediction!
Maybe it can be solved considering the apostrophe not as a word separator, but simply avoid the "space after insert" only after the apostrophe!
Or switching the apostrophe of the button 1, with the button > full stop<
(PS: How can I have the same layout of this picture? I think is better for Italian users, because we use more the > ! < than > - <,
we don't use the > - < for separated word like English users... )
In fact normal/old T9 keyboard use the button 1 for full stop, comma, etc....
I think it will be useful also for other languages! All the languages that use apostrophe!cyril wrote: Apostrophe Separator
consider apostrophe as a word separator (useful for Italian for instance)
I will try to help you!! Also making a donation to the developer, if it will be useful!!cyril wrote: @From the Topic >Add my custom words to the Italian dictionary pack<
But I agree the dictionary should contain all word flexions, I would be happy to improve it if I get some help (to find a good word frequency list with all word forms)
How I can do it?
- Phone: xperia x10 android 2.1
hi,
has this option been added yet? and if so, how do i access it in the options?
thanks!
thanks!
