Hello, is there any chance that Danish keyboard layout and dictionary will be in a future update.
Regards
Kenneth
Danish layout
Re: Danish layout
Hej
there is a chance, but as for every language I need a good word list (ordered by frequency) to do this.
So if you know where I can find a good one (with at least 5000 words if possible) I can add it right now
Tuborgmann
- Phone: nexus one
Re: Danish layout
Im not sure where to get one, but there is a danish dictionary that goes with the scandinavian keyboard on the market. Not sure if that helps any? Even getting a danish layout with: æ, ø and å without prediction and dictionary would be a start.
olle
- Phone: Nexus One 2.1
Re: Danish layout
If this was provided for swedish i would buy it in a heartbeat. The dictionaries distributed with scandinavian keyboard can be found here both in txt and xml:
http://code.google.com/p/scandinavian-k ... loads/list
Re: Danish layout
I'll have a look at these dictionaries.
As for the layout, you already have it, just use "English (international)"
olle
Re: Danish layout
The layout you get with English (International) is unfortunately not satisfactory. A layout like the one in Scandinavian keyboard (with international characters added on the default screen) would be preferable: http://www.cyrket.com/p/android/com.and ... norwegian/
Re: Danish layout
Understood... I will add these layouts
For the dictionaries, the only tricky part is that I want to deliver them in separate packages (as done by this scandinavian keyboard) and I don't know when I will have time to do this, but I can already add the layouts quite soon
Re: Danish layout
So, the scandinavian layouts are there ! I will add the dictionaries later as I won't have time in the next days
olle
Re: Danish layout
Great! Tell me if you need someone to test it on a nexus one.
Tuborgmann
- Phone: nexus one
Re: Danish layout
Great! Tanks a lot. Look forward to the dictionaries.cyril wrote:So, the scandinavian layouts are there ! I will add the dictionaries later as I won't have time in the next days
