Say we already have an open skin zip file. How can we set the suggestion bar image in skin.xml? Is it possible?cyril wrote:The problem is that the suggestion bar background is not a color but an image. So the only way to do this is to include the suggestion bar in the skins themselves
+1c00ller wrote:Say we already have an open skin zip file. How can we set the suggestion bar image in skin.xml? Is it possible?cyril wrote:The problem is that the suggestion bar background is not a color but an image. So the only way to do this is to include the suggestion bar in the skins themselves
I'm wondering because it is the only missing element needed to complete the "look" of certain skins, as posted above.
Code: Select all
<candidates>
<!-- Define the background of the suggestion bar -->
<background>
<image>keyboard_suggest_strip.9.png</image>
</background>
<!-- Define the divider bar between candidates -->
<divider>keyboard_suggest_strip_divider.png</divider>
<!-- Define suggestion text color -->
<colors>
<!-- Color of the typed word -->
<normal>#FFFFFFFF</normal>
<!-- Color of the recommended word -->
<recommended>#FFFCAE00</recommended>
<!-- Color of the other words -->
<other>#FFFCAE00</other>
</colors>
</candidates>
Yes, but I knew some people would notice it :p I changed this, now the candidate color set in the preferences is always taken into account as soon as it's changed, otherwise the color defined in the skin is used (which should be the case for most people)I'm trying the 4.2.0 beta you posted. The only problem I notice is it does not follow the color I chose in Advanced settings > Candidate color. It always stays orange. I suspect the new <candidates><colors> arguments in skin.xml overrides this setting?
The market link should not be broken, as the beta uses the same signature. Releases are announced on Twitter, you can subscribe to @dexilog.Also, a little off topic, but now that I'm using the beta I imagine the market link to the app is now broken. It looks like the release notes page http://www.dexilog.com/smartkeyboard/release-notes has no RSS feed. Also, there is no release announcement thread in the forums that I can subscribe to. I'd like to be notified when there is an official release, could you make one of the above possible?
