hey, on my physical keyboard for the samsung epic 4g, i can do the following things when not using your keyboard:
1. press fn, then press backspace, to delete a line
2. paste/copy/cut/select all: Menu+v/c/x/a
but your keyboard doesn't allow any such functions, is there anything you can do?
thanks!
standard keyboard features
- Phone: Samsung Epic 4G - Android 2.1
Re: standard keyboard features
um another thing I noticed about your keyboard app is that you can't insert smilies
like if I type:
something
on the keyboard, spaces included, this comes out:
something: )
because it automatically thinks the : is for grammar. that is good and useful but is there a way to disable that? lol, thanks
like if I type:
something
something: )
Interaction with the physical keyboard is complex, as each phone has some specific functions.. Hopefully physical keyboard support will improve over timedanielseeksGod wrote: 1. press fn, then press backspace, to delete a line
yes, disable "swap punctuation" option (it's off by default). Or just use the smiley key! (long press on enter key)because it automatically thinks the : is for grammar. that is good and useful but is there a way to disable that?
thank you but that also disables the good automatic replacements. will you please make it an option to automatically just disable the colon? :
