I wish a feature for changing the capital (upper/lower case) or respell a word with a double tap on the word.
It would be also cool if the written word shows instantly the actual capital (upper/lower case) on change, not until pressing the spacebar.
bye
double tap on the word for respelling or capital change
vandyke
- Phone: x10 mini
NickC
- Phone: Samsung Captivate Android 2.1
Re: double tap on the word for respelling or capital change
Completely agree on this point. Kind of silly to not show the capitalization until the word has been accepted. Distracting because I'm not sure if I changed the caps mode correctly.vandyke wrote:It would be also cool if the written word shows instantly the actual capital (upper/lower case) on change, not until pressing the spacebar.
Ad Fundum
- Phone: Samsung GT-i5800 Galaxy Apollo
Yes, when double tapping on a word, showing the suggestions again would be a very nice feature.vandyke wrote:I wish a feature for changing the capital (upper/lower case) or respell a word with a double tap on the word.
Absolutely!!!It would be also cool if the written word shows instantly the actual capital (upper/lower case) on change, not until pressing the spacebar.
chtamina
plus in italian all of our verbs are like this:
- portare (to bring)
- portalo (bring it to him)
- portarcelo (bring it to us)
- portarglierlo (bringing it to him)
but each time I have to multitap the whole word to add one of those even if my dictionary already has the main word (" portare" ).
So it would be great having a way to add a word not starting from scratch but starting from an existing word
nycebo
- Phone: Motorola Droid X
Actually, I would much prefer that it work like the stock multi-touch keyboard on the Droid X. A single-tap of a work brings up the suggestion bar again in order to change the word (Smart Keyboard doesn't do this currently). A double-tap actually highlights the word in case you want to write over it completely (Smart Keyboard Pro already as this as the default behavior and it is well used). Any chance of implementation? If you like, I can email over the apk for the stock keyboard.Ad Fundum wrote:Yes, when double tapping on a word, showing the suggestions again would be a very nice feature.
nick.koutrelakos
- Phone: Motorola Droid 2.0.1
I completely agree with this and would love to see it implemented.nycebo wrote:Actually, I would much prefer that it work like the stock multi-touch keyboard on the Droid X. A single-tap of a work brings up the suggestion bar again in order to change the word (Smart Keyboard doesn't do this currently). A double-tap actually highlights the word in case you want to write over it completely (Smart Keyboard Pro already as this as the default behavior and it is well used). Any chance of implementation? If you like, I can email over the apk for the stock keyboard.Ad Fundum wrote:Yes, when double tapping on a word, showing the suggestions again would be a very nice feature.
jpzsports
I agree with this too! This would be an excellent feature addition.nycebo wrote:Actually, I would much prefer that it work like the stock multi-touch keyboard on the Droid X. A single-tap of a work brings up the suggestion bar again in order to change the word (Smart Keyboard doesn't do this currently). A double-tap actually highlights the word in case you want to write over it completely (Smart Keyboard Pro already as this as the default behavior and it is well used). Any chance of implementation? If you like, I can email over the apk for the stock keyboard.Ad Fundum wrote:Yes, when double tapping on a word, showing the suggestions again would be a very nice feature.
Enhanced
- Phone: Captivate
Bumping this again for the word replacement feature. After using this keyboard for the greater part of my Android life and then trying the Gingerbread keyboard for a few weeks, I gotta say that this is the one feature that I would love for this keyboard to have.
Simply, I would like to single tap a word for the suggestion window to come up again for that word and then a single tap on a suggestion to replace that word. Preferably, a space would not be added after the replacement so there wouldn't be a double space.
Aside from the smaller keys that may make the Gingerbread keyboard more accurate, I believe that SKP beats it in almost every facet. The main feature of the GB feature is accuracy and word prediction and I think SKP is just as good, if not better. Keep up the good work!
nick.koutrelakos
Bump.
Cyril, any input?
Cyril, any input?
jpzsports
Please add this feature! It'd make things much easier.
