... handling
fatspirit
- Phone: Spica/2.1
... handling
Is it possible to add ... as a single punctuation unit? Now if it's typed after space, one point is swapped, but after second is typed, these two points are pushed back.
Re: ... handling
Are you talking about the latest pro version? If you type "(space)..." and have "swap punctuation" enabled, what you get is " ..."
fatspirit
- Phone: Spica/2.1
Re: ... handling
But it should be like "Well..." instead of "Well ..."
fatspirit
- Phone: Spica/2.1
Re: ... handling
They are autoinserted or picked from suggestion list.
fatspirit
- Phone: Spica/2.1
Re: ... handling
This issue won't be taken into account?
Re: ... handling
It will, but as usual I'm waiting for other feedbacks to give this more priority
nick.koutrelakos
- Phone: Motorola Droid 2.0.1
Re: ... handling
I've gotten pretty accustomed to just clicking the word i want (knowing i want periods after), pressing delete once, then adding periods. Simple enough.
Re: ... handling
Since … is officially one single punctuation mark called an ellipsis, most ideal is to replace three subsequent periods with … (Notice it's spelled as one character.) But I believe SMS doesn't support it, so it's useless.
