When the french layout is selected we only have the accents that are on real PC keyboard, while on the HTC HD2 we also have other european (latin?) accents, it is usefull for exemple if you are using french and hungarian, coz accents are not the same (for instance french use "à", hungarian use "á") . HD2 was nice for that
Is it possible to have an option for extra accents?
For reference here are the accents on the HD2 regardless of the langage setting.
àáâãäåæ
èéêëęě
űůüûúù
ïîíì
őøœöõôóò
ýÿ
Would be so great...
Thanks for the good job.
