i'm loving the iphone skin! perhaps just the fact that the keys are apart psychologically makes me type better. im not sure if i'm the only one but the contract of the letters vs the blue-hue background just isnt easy on the eyes. would it be possible to make the background a slightly lighter/bluer and make the key colors slightly lighter?
i cant seem to pinpoint why it looks so awkward hahaha
thanks! loving it the keyboard! best purchase in market!
also calibration tooltip a possibility in the future? i keep on seeming to hit the b instead of the spacebar and it's driving me nuts! (using the n1 and the home row keys have got me used to hitting the spacebar high) :\
iphone skin
tibere86
- Phone: Nexus One
Re: iphone skin
I'm having same issue with the iPhone skin. The phone keeps registering the "B" key rather than the Spacebar more often then with previous versions.
Re: iphone skin
I think the vertical correction has to be adapted a bit when using the iphone skin (as there is more empty space below the keys). I'll look at it
jab123
- Phone: nexus one 2.1
Re: iphone skin
this probably isn't in the right section but i felt this was too minor a problem to have its own thread, but the return key symbol on the iphone skin isn't centered vertically (which would be a fix purely for a looks)
thanks
thanks
