more sensitive swiping
Hi, would it be possible to maybe have an option to increase the sensitivity of the swiping options, as i find that when i swipe, it does nothing. i have tested other keyboards, and the swiping tends to be a lot more sensitive. please could you look into it. thanks
Sally Mack
- Phone: HTC Desire Froyo
Re: more sensitive swiping
I would have to agree with this... sometimes it takes me 2 or 3 swipes to trigger the action.
Increasing the sensitivity would have unexpected side effects on multitouch, so it's a bit dangerous, but there is probably room for improvement.
Anyway swipe works (almost
)100% of the time once you understand you need to really start the gesture from one end of the keyboard. Speed doesn't really matter if you do that.
Having just made a comment about swyping, I must say I didn't know about the "start the gesture from one end of the keyboard".
I assume I'm not the only one, so, perhaps You could mention it somewhere? (not sure where, perhaps in the changelog, or on a first swype?
I added this option in the latest beta. Sensitivity has also been increased by default.
Can you try?
Can you try?
wow. the new sensitivity option makes closing the kb waaaay more easy.
i already put a feature request out for a close button on the kb, but it seems it isn't necessary anymore.
GREAT new feature!!
ps: i don't use multitouch, i don't even know what the means when it comes to using a keyboard..
GREAT new feature!!
Thanks very much, it's a lot easiercyril wrote:I added this option in the latest beta. Sensitivity has also been increased by default.
Can you try?
