Arrow (with number) keypad and typing speed problem
keijun
Phone: Motorola X710 / v2.1
Post by keijun »
Please make a option that I can select the 'arrow keypad' as a default when I press '123' button.
In my case, I usually use arrow with numbers keypad more often.
In addition, from around v3.3 (I'm not sure, maybe between 3.2.2 and 3.3.1),
when I typing fast, sometimes it freezes in a short time so that wrong letter is typed(wrong letter means long-press letter, '@' instead of 'a')
It solved in the v3.5 however still it has the problem.
Both Korean and English.
Please enhance the typing speed (support fast typing without freeze)
Thank you
Re: Arrow (with number) keypad and typing speed problem
You can maybe define a swipe gesture to show the arrow keypad?
About the "freeze" which shows the alternative character, I think you can get rid of this by setting a longer delay for the long press
keijun
Post by keijun »
cyril wrote:You can maybe define a swipe gesture to show the arrow keypad?
Even I can change the arrow keypad with gesture, it's not comfortable.
Because sometimes when I swipe on the keypad, some keys pressed without change.
That's why I suggest this option.
I think the speed problem is about overall smart keyboard app, please enhance the speed.
Thank you :)
