What is the maximum size of the dictionary?
I may be able to provide different word list for Korean..
size of dictionary?
Re: size of dictionary?
Well, the Korean dictionary is already the biggest of all the dictionaries (except Japanese, which is a bit special) supported by Smart Keyboard Pro, with 1.1 MB and 53000 words.
I don't remember what is exactly the limit, but I think for Korean it will be reached for about 80000 words
I've sent the wordlist through gmail.
Hope it's useful.
Hope it's useful.
Ok actually the maximum was bigger than expected
I kept 180000 words from your word list, which gives a 2.5MB dictionary
You can try it here
You can try it here
Thanks!
It works well for me.
BTW, I noticed that the word suggestion does not work as I have expected.
For example, when I type '걱정ㄷ', the words 걱정된 and 걱정되다 and others are suggested.
But when I type '걱정도' or even '걱정되', no words are suggested.
Do you know why that happens?
Indeed there is a problem... I don't know why and I need some time for investigation
By the way do you think your word list is worth to be published on the market now? (apart from the bug you mentioned)
It seems okay overall, but I found some typos and so I'm changing the wordlist a little.
I'll be able to send you the new version, probably within the next week.
Thanks a lot
Thanks a lot
Just sent it through gmail.
Thanks!
Thanks!
Ok I have updated the file (ko_1-2.apk) you can download it again
I have included 200000 words this time (2.5 MB), this is quite big but I enabled the option to store it on the SD card
