A)
I really miss the accents on ABC DEF keyboard.
Without it it becomes almost fully useless since on portuguese accents can change all the meaning of a sentence.
B) enter not to send the message is also useful. Imagine that I want to enter WWW on ABC DEF keyboard
It should be: W, enter, W, enter, W, enter
That is faster than: W, waaiiiiitttttttttttttt, W, waiiiiiitttttttttt, W, wait, y, delete, w
C) If I need to switch smilie key to enter key and not have to swipe gestures enabled there is no way.
So: to select T9 keyboard: enable it on swipe then disable. It should be a option
thank you
Compact Querty, Compact keyboard Accents
luminoso
- Phone: HTC Magic
