Keeping punctuation shortcuts on text prediction bar!!
Everytime I try to type something, the punctuation shortcuts on the text prediction bar would disappear until either I press the space bar or select the word from the text prediction bar. This is highly annoying and slows down my typing. Is there a way to disable texts showing up on the text prediction bar while keeping the punctuation shortcuts there????
Re: Keeping punctuation shortcuts on text prediction bar!!
This bugs me too, but I would like to see both....
Not sure if it's what you're after, but if you select the option to 'swap punctuation' option,then when you hit the space bar the punctuation appears and moves into place when you type the next letter...
