The multi-touch works but not as good as other keyboards. going more into detail is that when i slide my both thumbs on the keyboard only one thumb is actually pressing the buttons. Example - if i slide my right thumb on the right side first then i start sliding my left thumb on the left side only the right side shows that keys are being pressed(changes to the pressed color). Please fix this
Also the landscape mode is good but the keys are a bit hard to reach maybe you can make it a split keyboard layout like Thumb Keyboard (two G's B's T's etc.) This would be great because i currently use this keyboard (smart keyboard) for portrait and it is the best!! But the landscape i use thumb keyboard.. Please reply!
Ps. i use a tool from the market to switch keyboards in different orientations automatically!
