i have 2 suggestions, just like perfect keyboard does, but this features don't exist in smart or smart behaves differently.
1. holding 123 key + alphabets -> you get symbolic -> then auto change the layout back to alpha.
2. remove the setting shortcut to "," key, and have option to enable/disable settings on "123" key if you hold it long enough.
