Example: If I'm typing the word "employer" for instance, it works fine if I press the M while I still have the initial E pressed. However, if I'm typing the word "the", if I press the H before I release my finger from the T, it only types the H and disregards the initial T press.
I'm presuming it assumes since the letters are relatively close together, my pressing the H was simply a correction of the initial T press.
Perhaps if this little problem could be fixed, it could be better than the stock android keyboard in the multi-touch regard. I'm unsure if this is an issue with the software or hardware though...
