google search
google search
suggestions and corrects dont work on the search bar. will it be possible to incorporate this feature?
Re: google search
It's on purpose.. the android framework tells the keyboard if it has to enable suggestions or not. And in the case of a search, the keyboard is instructed to disable suggestions. Of course it could be overriden by an optional setting, if that's really needed
Re: google search
I would definitely like an option for text prediction/correction in all text boxes that Android says should not have it. This would make my decision between Smart Keyboard & Better Keyboard a lot easier (which currently has this option)...that and Voice input (i know you know we want that
Re: google search
thanks! i love it! soooo helpful!
