Hello,
I am playing around with all the keyboards and i must say that this is the best one by far, but since i`m typing most of my stuff in Romanian, i`d like a way to turn off T9 and word prediction/autocomplete using a swipe maybe.
Turning off T9 from the keyboard doesn't do anything for me. Word completion is still on
Also are there any plans for a Romanian prediction dictionary?
Turn off T9/word prediction + RO Dictionary
Re: Turn off T9/word prediction + RO Dictionary
I can do this, or maybe add a "None" language which will have no dictionary
No plan for romanian, unless you find a good word list (with frequencies) which I could use
- Phone: Nexus One 2.1
Is there any way to ony make a big keyboard for the numbers? T9 style.
I added romanian layout, but I have a problem, as explained here ... http://www.secarica.ro/html/s-uri_si_t-uri.html
It seems the "ț" letter doesn't exist in the default android font (it can be changed if you have a rooted phone), but only "ţ" (though "ș" exists)
Should I implement the layout with the wrong character for compatibility, or the correct one (which means it will need another font on the phone) ?
Hi Cyril,
That is awesome news. Even without the "ț" and the "ș" it would be a great help. I have 4 friends who bought android phones, and this would make typing much faster:)
when do you expect to release it?
Thanks!
Thanks!
