Is there any way to add a new language "Malay". I would like to help in any way possible, like providing the word list.
Thanks.
Add language "Malay"
Re: Add language "Malay"
I also want a Malay language dictionary addition. I started studying Malay recently and I use the 12-key T9 with dictionary. I find myself having to switch to full-Qwerty keyboard and avoid dictionary to type Malay comfortably, which isn't so comfortable.
Malay is "Bahasa Melayu"(language of Malaysia) but Indonesian Malay ("Bahasa Indonesia") is pretty close and usable as a substitute. Unfortunately there isn't any dictionary for either of the languages.
I love Smart Keyboard Pro for the variety of features it offers, but the number 1 feature I love the most is that I can turn the annoying character preview pop-up off.
POSSIBLE QUICK FIX SOLUTION!
I have found a way to hack in a Malay dictionary into Smart Keyboard Pro using its user dictionary feature. I described the entire procedure (including materials needed) in my blog (hope it's OK to link a post on my blog here): ADTC (Computer): Smart Keyboard Pro - Malay Dictionary
Anyway I have collected 5400 more words (which don't exist in the dictionary above), but they are not all Malay words. I need help in discerning which ones are true Malay words, which ones are borrowed words used in Malay, and which don't belong to the language at all. I'm only a beginner so I can't do it myself. programatix or anyone else willing to help, please PM me. You must have good knowledge of Malay, preferably having studied it for years and uses it on a daily basis.
